WHERE DID YOU HAVE THE TEST DONE?
The max that was lost was 4 psi.
Toyota and I watch them do it. And they did a great jobWhere ?
What is your next step now ?
Did they send an oil sample to Blackstone to confirm no coolant in the oil ?
No but I have some of the old oil I'm sending. And I'm 99.99% it will come back positive. But we will see!
Positive for what? Coolant in the oil? John, if there had been coolant in the oil none of the leak down/compression crap would have been necessary. Anyone could have looked at the oil and seen it, especially given the quantities you say the system is losing.
That means unless there are Hydrocarbons in the coolant you do not have a bad HG. Have you tested the coolant for HC's?
If not, it's time. If that test comes back negative it's then time to find where the leak is, get on with life, and drive.
Well it's says there was no "oil in coolant" and everone is stumped. So drive it till it blows.... Idk at a lost right now. Ideas...¿?¿
This has already been done. And it passed ! One of the first things I didTool is available for "rent" at Autozone. I just used one. Paid $50 to rent it and got my money back when I turned it back in. See the video link for details.
The whole problem is that he's losing 1/2 gallon of coolant and maybe a quart of oil every 250 miles. He found a UV dye to put in the coolant and there is a green tint in the oil after adding the dye. This is the only test he's been able to find that indicates the exchange of coolant and oil inside the motor.
Other than that, we've identified a rear main seal leak, but that's it. He's trying to figure out where the coolant is going.
Roger that. The thing I'm getting at is (regardless of the Dye test) coolant can't be dumping into the oil in that volume without the guys at Toyota pulling out the dip and saying "Oh crap, there's a ton of water in there". That means unless there are HC's in the coolant the head gasket is fine.
Test strips for finding HC's in coolant are dirt cheap but it sounds like the guys at Toyota did not test the coolant.
Then, if that comes back negative, put the head gasket notion to rest and find out where the coolant is really leaking.
