- Thread starter
- #21
sorry edited it was a typo...
dieselcruiserhead said:General front axle cronology:
(Same for all LC in the USA)
C) 1976, switched to disk brake fronts, has "small" knuckle pattern for steering arms, slightly smaller birfields than later models so still slightly weaker. 4.10 gear ratio. Usually had weaker Warn hubs or other aftermarket (but usually Warns) installed at dealer compared to later Aisins but there are a few Aisins. In mid-late '78, there are a few pinions that were changed to fine spline making them stronger versus earlier models. All diffs still interchangable.
D) 1979, switched to bigger knuckle pattern, bigger birfield which would remain through 1989-1990 through end of 62 series that is also the same in minitrucks. Used a larger knuckle pattern for steering arms, also the same for mini trucks. Is the strongest. Switched to faster 3.73 axle gear ratio.
E) FJ60 models only: same as D but 2.75" wider.
F) 70 series models, same as D but I think 30 mm wider so about an inch wider?
E) FJ62 models only. Same as D but pinion angle was rotated up about 8 degrees towards T-case making for a "factory cut and turn" (still barely enough for a spring over but usable and better than no cut and turn). Gear ratio was returned to 4.10 but they have fine spline count so stronger. Also, axle is factory trussed, and disk brakes have a little wind scoop for better cooling.
PabloCruise said:Awesome - thanks Andre. This is exactly the stuff I was wondering about.
Isn't it true the FJ-55's in the US wore ASCO (Aisin) hubs?
Cruiserdrew said:On the Aisins and FJ55s-In the 76-78 era when the Birfield was fine spline, but slightly longer than the standard Birfields used 79-90, the FJ55s came with special "long" Aisin hubs, where the body of the hub is about 1/4 inch longer. I have one of these somewhere in the parts stash and it is an oddity. I was going to use it on my FJ40 but then just converted to FJ60 parts instead.
72cruiser said:wow.
great basic thread on axles. thanks a lot. (really great b/c it's not too longwinded...)
i'm tryin to decide on what axles to use for my soa, want to get rid of the coarse splined stuff in my 72 axles definitly, so the 62 axles seem like a good way to go.
any idea on average cost for a set of 62 axles?
i won't get robbed (i never have enough money to spend too much, ha ha) but i don't want to screw somebody if i buy them way too cheap.
malphrus
Advent said:How much could you outboard the springs on the FJ60 axle without the tires hitting the leaves at full lock?
I'm thinking about slinging an FJ60 axle under my front end when I do power steering as part of the prep for a Dana 60. I'd like the springs to be wide enough for the D60 so that's just less work later on.
