OK, she started up, kinda rough probably because I didn't put stabilizer in the gas and it's several months old. But she's running.
And she's moving, which is to say that 1st, 2nd and reverse function, but...
She's not shifting out of first gear when in D or 3. I ran her up to the redline in D and 3, and no shift. I assume it's actually 1st - I got to about 3000 rpm at 30mph. Then she'll coast.
I really have a hard time reading the dipstick on these things, probably because I recently filled it and there's still drips, but my first thought is that I overfilled. I put in 16qts, based on the spec and it still seems to be reading above the hot range according to the dipstick. The actual spec reads 16.3 US Qts. After re-reading
Cruiser Jimmie's A440F rebuild thread where he stated that he put in about 11.5qts, I drained about 2.5qts, bringing me to about 13.5 as I'm pretty sure Jimmie didn't touch the Torque converter, so that would have been about full from before the rebuild. I put about 2qts in the TC.
I had followed the FSM procedure of putting the transmission in N manually when I hooked up the shift lever. I assumed that was meant to align the N on the lever with the Neutral Safety switch, so I bolted up the linkage with the lever at N. I tested alignment by just putting it in neutral to see it roll, then stopping and putting it in P to verify that it didn't roll.
I had also adjusted the kick-down cable a little tighter than before when I re-installed, but when she didn't up-shift I dialed back to spec of .5-1.5mm.
Any ideas?
