- Joined
- Oct 22, 2013
- Threads
- 16
- Messages
- 258
Hey all, hope everyone had a great Christmas! I'm having a challenge I didn't expect. Hindsight says maybe I should have, maybe next transmission rebuild.
I'll spare you the saga, here's a summup: 1991 FJ80 with a 3FE and an A440F Transmission
1.) The truck's been sitting for about 7 months
2.) I pulled the transmission about 6 months ago, and been working on that rebuild slowly.
3.) About 3 months ago (Mid-Sept) I took a detour to replace my oil pan gasket & rear main seal (while I was at it, you know).
4.) About a week ago, we mounted the rebuilt transmission.
5.) When I attempted to rotate the engine to align the flex plate with the mounting holes in the torque converter, I found that I couldn't budge the engine with a big 18" crescent wrench on the crank pulley bolt.
Rotating the engine by hand was easy enough in June, I think I used a ratchet or breaker on the PS pully and rotated the crank with belt friction in order to remove the TC bolts when removing the transmission. There's no starter in the truck, it was removed as part of transmission removal.
Here's what I've done so far...
1.) Tried moving in both forward and reverse direction with big crescent wrench
2.) Removed spark plugs
4.) Drained the new oil I put in about a week ago (didn't want to contaminate brand new oil with penetrant)
4.) Sprayed PB Blaster into spark plug holes - left it for a couple hours
5.) Funneled Marvel Mystery Oil (MMO) into spark plug holes - about 1/2 quart total between all 6 cylinders - Left that for two days over Christmas
6.) Drained the MMO from the pan to verify that it had soaked it's way down through, got about as much as I'd expect.
7.) Tried moving crank in both forward and reverse direction with big crescent wrench
8.) Loosened all three accessory/fan belts
9.) Tried moving crank in both forward and reverse direction with big crescent wrench
One other thing - we were careful to push/rotate-3-clunk the TC all the way in, and the transmission pulled in with no fight, so I don't think it's torque converter interfering, but I'm open to anything.
But before I go unbolting the dang transmission again - am I missing something? Other engine moving techniques? Something dumb I forgot? Keep pouring MMO through it for another week?
There are many tales of 2-15 year sitting engines getting freed up, I'm not about to get stumped by 7 months sitting and changing an oil pan gasket. Least of all with a 3FE.
What say you, sages? Thanks in advance!!
