Gretsch
Been having some issues with my truck starting after sitting for a bit. Forced me to crank on the starter more than I should have. Forum pointed out some vacuum issues I had which helped but still the truck is hard to start after sitting. Better but longer than it should be. Still working through that stuff.
I got in it today and tried to start it. Lately the starter had been sort of sounding like it was binding up when trying to start the 2F. Real slow sounding like it was not getting enough juice to turn the engine. Kind of a whuh, pause, whuh, pause, whuh rhythm to it instead of the fast ch,ch,ch,ch sound I am used to. It finally started so I drove it to get the battery tested to see if it was bad battery. No luck. Tested good. Tried to start the truck to test charging and she would not budge. Just a 'whuh' sound and nothing. No clicking. Silence. Tried several times and the starter would sometimes crank over and then sometimes nothing at all. Sounded like it was getting bound up or something or the battery was not providing the juice it needed to spin it. This has been getting worse and worse over time to the point its at now, so I think its just wore out. I push started it to get it home where she is sitting now.
The FSM I have is missing the starter circuit section. I found a picture online that seems to show +12 through the fusible link bundle, to the starter key switch, and then down to the starter solenoid. There is also a direct +12 from batter to starter for the actual cranking power needed to turn it. Looks like there is no other relay in the diagram I am looking at so maybe everything needed is at the starter. Is this correct? Seems simple enough but wanted to rule out a relay or something I am not aware of I could look at as the cause of this and not the starter. The wiring is original AFAIK, and coincidentally I did just received a new cable kit from @Fourrunner I have not yet put on. I am trying to rule out anything else first before replacing the starter. Ignition key switch itself, wiring, other unknown to me relays, fusible links, etc. The manual I have goes into detail on rebuilding the starter but not much in the way of testing it. Any help here to either confirm or rule out the starter would be greatly appreciated. I do not mind replacing it to just add to the list of 'its been done'. But would prefer not to waste money if possible. I think I can remove it and have it tested on a bench to rule it out but kinda more trying to rule out anything I could check first outside of the starter before going that far. If its the only way then so be it. Thanks in advance.
