Yes, even with all of the traction aids turned off it still limits RPMs.
I was at an offroad training event this last weekend and one of the exercises we were doing was being stuck in a cross axle situation, and using left foot braking to shift weight and drive out of it. I had all of the electronic aids turned off (part of the training process). The technique involves holding the brake to the floor while increasing up to about 2500 RPMs. Both my land cruiser and several modern 4Runners found that the vehicle limited (cut) RPMs no matter how far you push the skinny pedal.
Thats it! When I got passed 2500rpm it would start cutting power depending on how much brake I was also applying. It was pretty slick and I've learned with no traction aids so I would lay into the brakes a good bit while gassing up some of the real slippery stuff to keep a constant load on the axles and there were many times it would cut power.
This is the first time I've had this happen to me or at least been pushing the 200 so hard I noticed it. I want to say I've been able to 2 foot in the past but those times my center diff never locked.
So I'm wonder if the computer was cutting the power to limit the amount of bind I was causing the t-case. Being biased to the front brakes and having that much pressure up front with a locked center only makes sense to cause serious bind up and might be why the computers cut power. There was one rocky climb where I thought my center diff was locked but I was getting a lot of wheel spin and was able to 2 foot up that properly. Got to the top tried to "disengage" center diff and heard it lock and then couldn't properly 2foot again.
Make you you press and "HOLD" the TRAC button until it illuminates the amber light on the Tach. Very helpful in sand.
Oh yea I hold it til it makes the dig and shows VCS disabled and the traction symbol. But then after locked the diff I got "check VCS system" or something along those lines and was never able to engage crawl control. First time I wasn't able to turn on crawl control was this trip. Was also 1st time center diff worked as it was supposed to throughout the weekend
