Any info from 3M on installation guildlines on silencer strips?
Seems like $42 a roll is the going price?
40 or so is a good discount price IME, retail somewhere around 70 IIRC. WRT installation, there really aren't instructions, but when I was first introduced to it 12 years ago by a body shop guy, it's center of a given panel 'first', diminishing rate of return doing the 'whole' panel. The bigger the panel, the better the rate of return (read: rear quarters). My usual method is to do a strip down the center lengthwise of the panel, then take half the distance between that center strip and the lengthwise edge of the panel. IIRC, on the PS rear quarter, it's a tight clearance at the storage bin to quarter.
When I did the tailgate a few months ago, I removed the carpet and cut the strips up and put them between the stampings, so that the carpet would sit flat again. I'll pic it tomorrow. I also took a couple a strips and went blind in thru the 3 tailgate access panels to get inside the double wall. Just closing the tailgate with a solid 'thud' instead of the typical 80 'clank', I knew the tailgate was a good place to go.
I spoke to a family friend Chrysler NVH engineer years ago, and he was not a big fan of dynomat at all. Educated me well on Density vs Barrier vs Absorption goals and targets. When I spoke to him recently regarding the rear resonator bracket differences removed vs installed, it was he that suggested the rubber isolator there. He also said on a heavy truck like the 80, solid pieces of steel bolted/welded to frames and brackets (+welded to exhausts) can do a lot for Mass/Absorption of rogue frequency generators. Haven't tried that yet, but have seen many brake setups with steel resonators hanging on them.
Don't forget to address those splash shields on the inner fenders as well. Less auxiliary noise coming into the engine bay, means less noise in the cabin as well.
HTH
Scott J
94 FZJ80 Supercharged - selectively 3M'd
