Love to hear these kind of stories- another 40 saved from some dip***t.
A most excellent find. Good for you. Y'know, I've got the original late F block from my Pig still sitting in the garage (been rebuilt once)...if you want to put your late F head on it. Of course, a 2F would work just as well.
So what would cause a valve to stick like that?
It could have been an oiling problem. the oil tub was not pumping oil to the top end. so mark suggested an external oiling system.
So I had a oil line made that goes from the oil sending unit around the block thew the valve cover, to the rocker assembly there i used a 6" loop so i can move the cover out of the way to august the valves it puts out a good bit of oil now.
I can post some pics if you like
Sweet find and great team work!!!!
Hey John, the cops haven't called you yet for that theft? $3000? A steal if ever there was one! That looks like a Tiger Top from Specialty Tops. My 74 has one as well. I need to replace the velcro on the inside. That top has held up well for me over the years. What kind of rear bumper is that, with the centered spare? So are ya gonna drive it up for the 45 run? Awesome looking truck. I like it when one of the good guys wins!
Like the set up for the external oiling system you and Mark set up.......simple but brilliantly effective!; what size line did you use and how did you tap it in?.......please share the dirty details
Lou
I would also check for a grenaded or loose valve guide, and for a broken down valve stem seal. I've had the latter happen and make my valve stick, and we've seen the former here on Mud recently. Both may be the result of poor oiling, I expect.
