2001LC
Wow look at that. A new inspection I'm going to do!Uh oh. Found the gas fume culprit. Rusted edge of gas tank.
Build a heatshield as shown in that thread. After that the issue should disappear completely.
It's a super simple mod. Maybe I'll actually do it today now that the temps are warming up. I'm going to do the other side too to shield the AC lines.Which thread on building a heat shield?? I have same issue in an 04.
Thank you.
Guys, i just posted this on the "Engine shutting of on long trips thread", which i started a couple of years ago...
UPDATE: I went on a fishing trip in early august. The temperatures were 90-110 the entire way. It's been an early and hot summer this year in s. california. I filled up the land cruiser with a full tank half way through the trip. There were no symptoms whatsoever. No vacuum when opening the gas cap, no hissing, no gas boiling or even smell of gas when driving. This trip had the high temp and elevation gains which has CONSISTENTLY caused the symptoms mentioned previously, but the LC experienced no such symptoms this time!
I believe there are 2 problems on these LC's, one is a charcoal canister and fuel tank vent which caused the engine to sputter and die and on 06-07 models (possibly earlier as well), need to be replaced with updated units. The second are the fuel lines run near catalytic converter causing to fuel to overheat.
Lastly, i added a heat shield near the catalytic converter to block radiant heat which caused the gas to get hot, taking off the previous temporary heat wrap i had wrapped the fuel lines in. The heat shield is 24 gauge sheetmetal, 23" by 3.5", riveted to the existing cat heat shield. I added thermotec heat shield to the sheetmetal, only because i had it laying around, i believe it is NOT necessary...
I'm posting detailed work and results on this topic because, frankly, this was a huge PITA for me and had me considering selling the LC but i believe it's solved once and for all...
I am doing both sides this weekend too. Where are you sourcing the metal? Lowes?It's a super simple mod. Maybe I'll actually do it today now that the temps are warming up. I'm going to do the other side too to shield the AC lines.
100 Caught fire & gas tank venting concerns
