- Thread starter
- #61
Update
Here is a photo of the first adaptor with the AA adaptor next to it for reference. (new plate on the top) The bolt holes are off a little bit, so they are being moved a little bit.
Also here is a pict of using the CNC in order to locate the holes more accurately. Locator "pins" are installed in the bolt holes, then a sensor is used to find the exact center of the pin for placement of the holes. The first time they were measured by hand, and were close, but not close enough... The bolts would install in the holes, but depending how they were tightened down, it would cause the plate to shift about 0.060" to one side or the other. The machinist did not like it, and is doing it over.
Shouldn't be too long now...
Shawn
Shawn
