Builds Shoppy's Moonlight 80 LS1 Build 2017
Are the bowed coils common? Is this something the OME J spring guys, along with SLEE 4" guys would be have to deal with as well? (I get how rotating the 3rd upward at ride height will do this... and I can see how adjustable upper arms can rotate it back down. Is the issue that everything is now moved back and the mounts are offset?)
The length of the Lower arm off set is only 11mm , I think the longer spring is where the bow comes in. Add a slight off center spring mount and some flex and you get a bowed spring. The fronts bow quite a bit more than the rears on mine.
Do you happen to know the P/N for the supra fuel pump or the exact model to order it for ?
Thanks.
Thanks.
Dense 950-0155 fuel pump, modified the LC pump hanger just slightly and attached the new pump with a hose clamp for extra support. Worked nicely and can’t even hear it
Here are some finished engine bay pics, prior to the second battery install
Boyz got some mad welding skillz.
Great build Shoppy!!!
Yeah & how is the tan shop truck coming along also?
