Quick question:
I ordered some new rotors for my 1998 HZJ75. I am currently at the stage that I have removed everything, but I have no clue how to separate the current disc from the hub.
I have the 6 lug nut version and there are no additional bolts or threaded holes foreseen in my current set up.
Is it just a matter of using a hammer to tap out the wheel stud bolts (with the nuts on to not damage the threads) then separating the rotor from the hub assembly?
I also bought new rotors that have the same six holes in them but also a couple of extra ones obviously for a different type of hub assembly. Could I still use these on this setup or is it better to look for a matching hub assembly?
Thanks a lot!
Thanks a lot!
