Second Fuel Filter?
I found what appears to be a second fuel filter on a line near the filler. It's smaller than the filter near the engine, and it's made of plastic. It's in that mess of tubes covered by the grey panel behind the passenger seat. It looks stock because it has those funky OEM hose clamps on it. Is this another fuel filter, or is it some kind of check valve? I could blow air through both ends of it, but it took a lot of pressure. It's on my '77 FJ40. I apologize for not taking any pics of it.
FJ40Jim
The Cruiser Whisperer
Lancaster, Ohio, USA
Website
www.tlcperformance.com
It's a pressure check valve to kep some vapor pressure in the tank. Generally speaking, it's a good thing for off-road use, helps keep excessive liquid & vapor from filling the carcoal canister.
california
Does any one know where to buy this pressure check valve ? Mine is right next to the metal fuel filter ... it’s a clear yellow / filter inside looking deal
california
Here’s a picture
73FJ40
After another night of rust removal!
Western Massachusetts
Okay, the silver metal can with the wire attached is the oil pressure sending unit.
That yellow filter is a fuel filter, not a check valve.
The check valve referred to above is typically located just below the fuel filler pipe, though I'm not certain on the location for your year.
california
Got it - I’m getting ready to have a new Carburetor put in , so I am guessing I should put a new fuel filter on as well for good measure ? Do you think the filter is a generic or needs to be ordered from one of the specialty dealers online ?
73FJ40
ps - just upgrades to Silver Star
Good Move!
You should strongly consider replacing the filter, and all the flexible hoses between the tank and the carburetor, unless you know they've been replaced recently. The filter you have looks like a standard 5/16" size.
Ethanol in gasoline is not good for the flexible hoses.
JohnnyC
Long ago TLCA# 2231
UpState Ny, Wells Me
california
Good Move!
Definitely will do the filter - the hoses feel pretty good still, but I will try and do a better inspection
I've been using these inexpensive filters from O'Reilly's to filter out the sediment from my tank. They come packaged with two peices of flexible hose and 4 spring clamps. Under $4 each.
