I had photographic evidence of work this day!
PS fluid going in. I went with non-ATF. couldn't find good answers on which to use. Seems liek the engine is new enough to want the new stuff.
I tried to start it that night at around 10pm, we were both tired and couldn't get it to work.
Mumma making out with Mattie:
In the morning I read the install guide and learned about the hand priming pump in the fuel filter housing. Once I pumped it up (SNL reference), this happened:
As I mentioned Cummins proper knows nothing of these engines and parts. It had taken me about 4 months with a Cummins parts guy in Winnipeg to get that connector lying on the floor there, including one pair that I ordered, were wrong and had to return. This one was slightly too big and fuel sprayed all over the place.
I had the straight connector to use instead that did fit but its not as nice as a 90 would be.
Anyway, not sure how to post a video, but yesterday she came to life!!!
I had some wiring gremlins to fix after that:
I shortened all the wires in the cab side harness and had made a mistake with the murphy switch wiring. I had the resistor connected to the ECM but the ODBII and the Murphy connector were only connected to each other! Fixed, then the murphy told me I had no throttle pedal.
I shortened and repinned the throttle cable and the pins didn't lock, so when I pushed it onto the throttle the pins shoved back out of the way. Got it to work now but may need to replace that connector. I learned from the facebook group that you aren't supposed to cut the thottle cable at all, it uses a duplicate signal as a failsafe. So far it is working so I will assume that they are still close enough in length not to cause an issue.
The headlight power pin in the connector was in upside down so when I pushe it on, it pushed the pin back and I had no headlights, now fixed.
No driver's headlight, wires had pulled out of the deutsch pins so I redid them and crimped the small ones twice (one downside of LED lighting, wires are generally quite small).
Reinstalled the driveshafts.
