- Thread starter
- #121
I disagree @jerryb Warp may not be best word to use, but is most common. Hot spot may be better.Hum. He said; they sometimes see rotor show themselves as warped only when hot.
Not trying to cause a stir, I just thought that was the most silly thing I've heard in a long time. This is just another opinion, for example.
-Warped- Brake Disc and Other Myths
As soon as "he said" that a light went off in my head
, concerning issue with steering wheel vibrating in a video text i received from Snowy's new owner. I could see his RPM dropped then speed and shiftier was in D, as steering wheel began vibrating. This indicates braking used to control speed in HWY down hill driving, not a good idea. Gear down people or brakes may overheat and fail!I don't use brakes to control speed in down hill runs, as it's foreign to me driving in mountains, which I've done all my life. To do so heats the brakes and they can fail. I've seen countless drivers use runaway ramp's from loosing brakes, as they smoke. Most of those are the "pros" 18 wheeler's that fail to down shift as required.
I also recalled Snowy's rotors were replaced less than 50K miles ago with aftermarket and OEM pads, not a bad combination. But if not broken in properly (seated) they can develop hot spots. One reason we break in rotor is to heat them evenly, to condition the metal. Procedure is to ride the brake peddle slowing but not stopping from 35 MPH, three time before using brakes to stop. Stopping during this break-in will create excessive heat on rotor at point under pad(s) as rest of rotor disk metal cools at different rate. This can create uneven metal conditioning, a hot spot. Hope that makes sense. If that hot spot is uneven material transfer or uneven Annealing I can't say.
Theory was; as rotor heated it would expand differently in that one hot spot then in the rest of surface area of rotor disk.
This explained why I did not experience the steering wheel vibration, driving the Rocky Mountain HWYs on my test drive in the long 8%, 12% and even some 18% downhill grades.
Snowy's new owner was told by an ASE certified Mechanic "front end was junk and needed a total rebuild" or some BS like that. I called BS. I explained what I thought was issue. I also reminded him, I offered to rebuild brakes while in my shop, as one front inner PS pad was a bit thinner than others, but could last 30K miles the way I drive. (I get 90K plus on fronts). Offer was declined, due to possible delaying timing of pick-up.
He now took my recommendation, and had Dealer turn Rotor on the rig. He did not replace pad (I would have, as I always do both together).
He reported problem solved after rotors turned!
Can't think of any better example of a warped rotor. Again semantics, condition is actually a "Hot spot" (for lack of better word) from not breaking in properly.
