Saginaw twisted spline? (2 Viewers)
Chattanooga, TN
Well...I guess this either happened on "Bends and Dents" at Gray Rock or in my yard when I broke the drag link on a unseen stump. :doh:
As you can see below I "candy-caned" the splined output shaft on the Saginaw gear which begs the question...what do I do now? Do I have to have a new box drilled and tapped ( I have WTOR's ram assist) or can I just replace the output shaft?
BTW Poser, the H41/Orion is great! More to follow on that soon..
Fire away...
that is bad ass! first time i ever saw that.
I think you can just swap the shaft. Maybe get your next one cryo'd
Todd-
I replaced my steering gear in '99 with a Cadilac/J20 steering gear when the used '71 Impala steering gear that I had been using since '91 did that.
I have since installed a ported steering gear from PSC for the hydraulic assist set up that I am using.
Glad that everything went smoothly with the H41/Orion.
Thank you!
-Steve
Absolutely, that would be the best way to go.
If the pinion is twisted like that, what is the condition of everything else? Just get a quality steering gear ported and ready to go and swap it out.
:beer:
I saw a twisted sector ONCE, a couple of years ago at the Hammers.
Belonged to some guy from TX named Nolen.
He said it was "work hardened".
:eek: :eek: :eek:
x2 on what Steve said. The force that 'created' that presumably is strong enough to damage any other part in the box of a smaller size [which is pretty much EVERYTHING!]
While getting ready to call PSC tomorrow and went out to count the input shaft splines and measure and found this... :confused:
This maybe a stupid question, but is there supposed to be a flat spot on the splined shaft? If not, why the fawk is it there? If so than I have a 13/16 30 spline...does this make sense???
Todd
Flat spot- Yes.
13/16"- 36 spline (If there were splines in the flat area, they would total 36)
I have seen quite a few barber poled output shafts in the last few years, usually after someone hit a full size truck in the front tire though.
Dave
not heavy enough :flipoff2:
Snapped the drag link like a twig, but guess it held out long enough twist the sector shaft...
Unlike some people, I'm perfectly willing to put my stupidity up for the world to see.
:cheers:
Find a new ptiman arm while you are at it, chances are it tweaked as well.
Dave
Todd-
-Steve
Sorry about the hijack Todd. Steve, what models were the J20's used in? ALso for both of you, which adapter kit do you recommend? I found one at one time that had a strong looking collar thing but now I can't find it ... maybe Proffit's?
Thanks Guys!
This is starting to be more common on the rubicon, usually they just shear off. I carry a spare SECTOR SHAFT, very easy to replace on the trail. take off your pittman arm, remove the top 4 bolts from the top of your steering box, pop out the broken/bent sector shaft, slide in your spare and bolt together, Adjust the free play. Now you are up and running again. John
Thanks Guys!
NAPA part number is 51-6529
J20 is a Jeep 3/4 ton 4x4 pickup...
1976 is the year that I use when 'looking it up' online or with another auto drone store...
:beer:
Auto Zone's part number is just 6529. I got mine for around $200 ish if I remember correctly. This box is definitely the way to go, I love mine. Here is a picture showing the larger J20 box compared to a 4 bolt box that I snagged out of a mid 80's wagoneer.
More:
