- Thread starter
- #21
That shackle isn't helping a bit and could be binding that one spring to not allow the axle to rest on it's correct castor angle . Also, look very closely at the springs both fore and aft of the spring perches and make sure they aren't bent , usually pretty obvious .
Sarge
Thanks sarge,
The one in question - obviously this one is being pulled inward by the shackle, so it has to be bending, at least slightly. Not sure how to tell whether or not it is permanent without unbolting the shackle. What's the recourse there - can bent springs be "unbent" effectively, or am I looking at new springs? I'd probably be looking at replacing all 4 if that was the case, as I have no idea who made the ones currently installed...
Hey Sarge (and others),
What about that question - if a leaf spring is torqued, particularly twisted, is it shot, or can it be salvaged?
Again, not sure as the the extend of the twist in the spring (or if it will untwist itself when I remove the shackle) just trying to figure out what might need to happen!
Thanks!
