I don't have any ac so it would have to be the heater. But wouldn't it smell like coolant if it was the heater core?If you are getting a leak under the dash near the passenger side that would lead me to believe that it is either the AC Condenser or the Heater Core that are leaking. Both require dismantling the dash from my reading.
Check the grommets around things passing through your firewall. That's where my FJ62 leaked water into the passenger footwell.
You are doing good work, keep it up!
Awesome thanks for the advice! I am going to run a test by running water down that side of the vehicle and see if I can visibly see where it's coming from! If it's the grommet what would be the best way to block it from there?Not necessarily. Definitely worth a check to shine a flashlight back there and start poking around to see if you can rule out that it is not leaking.
DEFINITELY THIS!! There is one large grommet on the passenger side under the windshield washer reservoir that leads into the cab. You could be getting something that is leaking there and touching on the wires and just following them in. Pull the side kick panel as well (need to anyways to look at the grommet from the inside) and make sure you don't have some weird leak coming from the raingutter down the door or anything.
@tmxmotorsports this needs to happen to mine....wolf steel is the vendor... following this thread..nice work!!
Oh and here are the abrasive pads I was talking about. My buddy that did body work for a number of years called them "hamburgers".
yeah they are just thicker, open cell abrasive pads, I guess kinda like big versions of a 3M Scotchbrite pad. They do a great job of stripping paint and bondo and whatnot but don't heat up the metal like a true abrasive pad/flap disc would. And the larger surface area also makes it nice for stripping things off quickly.That's a new one to me. I'm definitely going to track one down and try it out.
Eric
@SharpasMarbles and @tmxmotorsports Don't forget that Jason (@reevesci) also sells the dog leg and quarter patch panels as well. Don't know if he is cheaper than Wolf or not, but its J so you know it is quality stuff.@tmxmotorsports this needs to happen to mine....wolf steel is the vendor... following this thread..nice work!!
Yes thanks for advice it really sped things up! Yeah I also got a couple of those "hamburgers" I'll try those out today. The flap disc was working so well I didn't want to change anything up!NIce work dude!!! I see you went and grabbed one of the angle grinders finally instead of trying by hand!
I really don't think it would be the windshield because I just got a new window gasket.Don't rule out the lower windshield corners as the source of your leak...
