Rear windshield wiper HELP!! My rear wiper has only been working when the rear hatch is open. I just replaced the wires so I know they are not frayed or broken. If I start it and then lower the hatch it works but won't start with it closed! Has anyone ever experienced this!?
I am actually just getting started cutting this section out. I looked at trying to get replacement panels or anything for it but I decided to just cut it all out and then just do my best to form it so it half way matches the contour of the rest of the floor. I am not to worried about since it will be covered by carpet and a seat so I just want it sealed more than looking pretty. Once I am finished with it I will put up some photos.Hey @kev60 How did you end up repairing this section?
I thought it could be a break in one of the wires too but I had just put in a new to me rear hatch and checked all of the wires. But I guess I could have always missed something so I will have tot take it all part again. Thanks for the advice!Power windows worked occasionally on a truck I used to own. Turned out to be the wiring harness. The opening and closing of the door eventually caused a break in one off the wires. If I was lucky, the wire would make contact and my windows worked. I eventually cut open the harness and soldered the break together. Taped the harness back up and was good to go.
Another possibility could be the connector. Possibly the connector is getting enough of a tug when you open the tailgate that it closes the circuit. The fix might be as easy as cleaning the contacts and using dielectric grease before reconnecting the harness.
I'm leaning towards the harness having a break at the bend where the tailgate opens/closes as opposed to the connector being corroded.
Well thanks for the great advice I am now on the hunt for someone local with a SOA... This may be the hardest part haha...Yes to both questions. The key is to find 2 pre- 85 fj60 front driveshafts and have them lengthened to utilize the Double Cardan joint. I think I have about $250 in my driveshafts ($200 to have them lengthened/ balanced) Brake lines can be bought off a vendor and are fairly cheap.
I recommend taking the time to find someone local with a SOA 60 and see if you can at least go for a ride-a-long. Real world experience trumps internet research ten fold. Point is, don't listen to the opinions of those who haven't graduated from an Old man emu setup..
-McGuire
