This electrolysis rust removal using a DC welder as a power source seems pretty cheap and effective . Here are some links
http://antique-engines.com/trailer-electrolysis.htm
http://antique-engines.com/electrol.asp
ok so...if i read that right you hook up the positive lead to the re-bar or whatever piece of steel that just touches the water and then the negitive up to the wire that goes to the part....iv seen this before and thought it was a cool idea but also read that it CAN weaken the part being cleaned due to a chemical change in the steel...great for body parts ect. dunno if it would be the best idea on a frame because of this but great for body parts![]()
The electrolysis causes hydrogen gas production at the cathode (your derusted part), which diffuses into the metal and can cause the metal to be brittle, but the hydrogen diffuses out slowly over a few days, so the metal goes back to normal.
Why you should not use stainless steel electrodes for electrolysis
Many people using the electrolysis method for rust reduction swear by stainless steel, stating (incorrectly) that it's not consumed, stays clean and seems safe.
Stainless steel is indeed consumed when used in the electrolysis process, although slowly. The main problem with using it is the hazardous waste it produces. Stainless steel contains chromium. The electrodes, and thus the chromium is consumed, and you end up with poisonous chromates in your electrolyte. Dumping these on the ground or down the drain is illegal. The compounds can cause severe skin problems and ultimately, cancer. Hexavalent chromate is poisonous. These compounds are not excused from hazardous waste regulations where household wastes are.
These compounds are bad enough that government regulations mandate "elimination of hexavalent chromate by 2007 for corrosion protection."
Does your electrolyte turn yellow? That's a sign of chromates.
If you have been using stainless steel for the anodes (positive electrodes), wear rubber gloves when working with or near the liquids. If you need to dispose of it, allow it to evaporate into powders and dispose of the powders in sealed containers during your local "hazardous waste clean-up days".
Best bet - don't use stainless steel no matter how tempting it is.
Saw some mention of NOT using stainless in one of the links but didn't see why.
Will the stainless in your new tank deteriorate over time? There is a place here locally that gets all kinds of industrial pieces parts as salvage. I guess I'm looking for a tank now.
Anybody ever dip their tub like in the first link? I have some floor corrosion I'm thinking of converting.
These compounds are bad enough that government regulations mandate "elimination of Hexavalent chromate by 2007 for corrosion protection."
