I've decided that I am going to take my Hundy to the Rubithon this year, time to start prepping. I'll be going on the Wagon run, anyone else in?
Sounds like good shake-down runsIf you two can run trails like Mt Blanca & Holy Cross trails in CO w/o issues, then Rubicon might be up your alley.
Yes, I have factory rear, and an ARB front. As prep for the trip I will be:
- Adding a 1" body lift (already have it)
- Getting 35" tires on 18" rims (picked up a set of Tundra wheels). Going with the 18", to get a skinnier 35"er
- Adding a winch
- Adding Slee body plates
Spares: CV's, Axles, Starter (already have all of these), and will be adding a few other bits in addition to the normal backups I usually carry.
The new Nitto Trail Grappler 285/75/18's were installed today with the Tundra rims. Next up is a winch in a couple weeks. Most of the maintenance items have been completed.
Without, several people have had these work without the body lift. I noticed its slightly rubbing on the inner fender plastic, which I can adjust. I'll be testing how it handles on turn/compression soon. I may be adding spacers to bump the tires out, as right now they are inside the fender well.Is that with or without the body lift?
