Builds rocks and rolls
started to cap off the rear wheel wells.
Was working late and the bead roller was unavailable so I decided to use the original wheel well that I cut out
clamped in passenger side
The tunnel cover is ugly but I could not figure any other way to do it.
Took a full day to finish
Moved on to the gas tank
had to cut a little more off the tank to fit the tunnel cover
tank partially finished
I am going to pressure test for leaks then I am going to have a local shop line the inside and outside of the tank
I am anxious to see what the tank capacity is. I am hoping it holds at least 10 or 12 gallons...
snug fit
Diesel Dan,
The tranny hump comes off the floor in 3 pieces for access to the shifters, the tcase and the tranny if and when I need to ever take them out.
I havent timed the shifters yet but hopefully soon..
I can see about 2 days of fabrication work you have done there.
You are going to have one heck of a time adjusting the linkage with the welded on tranny hump. Did you already add fluid to the T-case? :hhmm:
