Resto journey (1 Viewer)
r71
Atlanta
I don't have a plan. It's just shoot from the hip. Make it up as it goes along. But I will post from time to time the progress. I'm definitely doing a LS. But will concentrate on the restoration part more. Gonna take her down to frame, acid dip all metals, ets. Should be fun.
No plan is a terrible idea.
why would you tear apart the truck before doing the swap? Way better to do all the swap projects while the vehicle is assembled. That way you can build and test everything, then tear down and paint everything after.
I’m so confused.
You said you are swapping the second one as well.
Either way, I’m here with all the LS swap parts you’ll need once you have a plan, or if you need help making a plan.
