Looks awesome
Also, got the rear Chevy 63 springs put in and while I was at it moved the rear axle back a few inches. Will need to trim thh rear fender well a bit but proportionally I think it looks much better.
Before:
After:
Still need to mount the rear shackles and my delema is, do I want to mount the shackle hangers under the frame or plate the rear frame so I can mount the bushing through the frame. Figure the difference in ride height between the two is approximately 2".
Anyone put the bushings through the frame in the rear when swapping to 63" springs?
Also, does any one have any recommendations on alternative front springs? I am having zero luck on a set of stock rear springs. Would like to go to something else so I can set the OME springs as a set.
How about use your old rear springs up front?
Have u tried a wanted ad in classifieds here? That usually finds me parts
Yeah, and no luck. Going to post the springs for sale and make a caveat that I get the stock rear springs.
Been busy the last couple of weeks but was able to build a shifter mount over the weekend after taking the son out to the Nor Cal Rock Races at Prairie City OHV Park.
Decided to go with the Winters / Art Carr Side Winder shifter. Only problem was if I mounted it straight to the trans tunnel floor, it was too low for my tastes and I wanted it up higher at a more comfortable level.
Started with some dimple die action
Base coats of paint
Installed
On a side note, I am looking for some type of rubber mat that goes from footwell to footwell up front, to cover up the holes in the carpet from where the original shifters were. Does anybody make a rubber mat for the 60s or know a good base material to use. I was thinking stall mat at first but it would be way too thick.
I really like fj62 throttle pedal and cable setups . It is looking really good . I like the idea of 60 rears up front as well.Can anyone give ideas on how to make the throttle cable work with the original pedal?
There's a set of stock springs on Portland Craigslist. Last I looked he wanted $450.Yeah, and no luck. Going to post the springs for sale and make a caveat that I get the stock rear springs.
