Rear Heavy Duty Swaybar owners got links that last? (8 Viewers)
Photo courtesy of a happy customer in Australia equipped with our Front Swaybar Disconnects and Severe Duty Rear Links. Nice flex!
For the guys that needed the Rivnuts
Speaking of installation is there any instructions or tips on how to properly align these links? I checked LCP website and couldn't find anything. I'm not sure what I need to drill out too. Thanks
RIVNUT install - You should have small holes in the frame where the brackets go. The drill bit is 1/16 undersized because you want the tightest fit possible with the Rivnut. Drill the hole and you may need to wiggle the drill/bit a little for a tight fit. You also have an extra Rivnut if needed or to play with. The install tool now uses an Allen head bolt. In the past the install bolt was 10.9 and installations Rivnut was breaking so we upgraded to 12.9.
The video should help -
Ideally, for offroading, I want to adjust the links so the swaybar is at the same level as your lower control arm. If needed you can opt to not use the lower jam nut to this will shorten the assembly.
these things are killer, Thanks Phil!
and yeah, dont get all balzy and drill the holes too big for the Rivnuts.
Good point on drilling....reason the drill bit supplied is slightly undersized.
Pro install tip - When tightening the upper jam nut placing a 3/4 open end wrench along the side of the heim will keep it in the center for optimal travel.
and apply anti-seize on the threads for future adjustment if you live in the salt road area.
