This may be a question I should have asked before. I just installed the JT Outfitters rear disc conversion kit. Now, I have a big question... this means I can't install the OEM parking brake on the rear driver's side wheel?
OEM parking brake is on the rear of the transfercase... unless i'm missing something on mine?
Hi All:
The 1981-84 BJ/FJ40/42 came with a rear axle-mounted parking brake not unlike that featured on the 1981-89 BJ/FJ/HJ60/61/62.
No, the common "Monte Carlo" rear disc brake swap done on pre-1981 40 Series is not compatible with the OE rear axle parking brake.
The GM/Cadillac "El Dorado" rear axle calipers with parking brake feature were designed to have a floor mounted pedal provide the engaging force, which an under dash or between the seats mounted p-brake engagement lever simply cannot provide.
An idea would be to use the rear axle disc brake calipers from a 1988-96 Isuzu Trooper, which has an under the dash mounted engagement lever.
Good luck!
Alan
Will the Isuzu Trooper calipers fit the common JT's/Posers brakets? found this picture on Rockauto
I used eldorado calipers, had a big problem getting them to hold. Visited the local boat store and bought 4 small pulleys designed for steel cable and hooked up a pulley system. Lots of leverage now....
I'm wondering how effective the parking brake feature is on those. I had El Dorado ones on my FJ62 with the parking brake and they sucked. No kind of clamping force when using the parking brake.
