Aloha Folks,
So I was test fitting my Real Steel Bows in preparation for a TrollHole Top to get here but I ran into a bit of a snag.
The "B-Pillar" bow (front-most) sits almost 3" higher than the rear-most. It seems fully seated in the body panel, hitting the inner stop. I did some searching for dimensions and stumbled on a pretty old thread that had some dimensions from an OEM set, compared with that my front bow is indeed about 3" longer.
My question is for anyone that has a set from Real Steel or knows of the dimensions, what is your measured height of the "B-Pillar"? Should I just cut it to length or am I doing something wrong...
Thanks
*Edit* Just wanted to add that I had to re-drill holes for the joining bolt on the "B-Pillar" bow because they didn't line up at all. Not that it matters really, just doesn't speak well for QA.
Thanks
