Question about lx470 lift (1 Viewer)
You can easily run 33” tires on stock height. I did that for years.
my concern is once there is 300lb in the back and 300lb in the front not including passengers, it’s going to sit even lower. I think I like yotaMDs suggestions. I’ll probably do medium duty springs in back and either adjust the torsion bars or by new ome ones when I add all the weight so it’s not sagging in front or rear.
Hopefully I am understanding this correctly. This is my first 4wd vehicle ever.
I am not understanding what tire size has to do with cargo/vehicle weight?
if your AHC is working correctly it should never sit lower than it's supposed to on the N setting. It's designed to keep it at that height. If it cant handle the weight it will drop into low and that's when you should be worried about adjusting pressures and messing with other stuff.
Hang on a second. I think we need some grounding here.
@LowDrag82 A numbered list of things for your consideration:
1. Lift height has nothing to do with tire size on a 100 series. Run 33's. That's fine with stock AHC at stock heights. I run 33.5" tires on slightly more aggressive stance wheels at stock heights. It needed a veeeeery slight reshaping of the fender liner. Zero metal bashing and zero cutting of anything. It's fine. 33.0" tires like a 275//70/18 are just fine with no liner reshaping. The problem with big tires on a 100 is the pinch weld area directly behind the front wheels. A lift does nothing to change that. In other vehicles, it's common to lift the car to fit bigger tires. That's not applicable to the 100 series. It's not a thing.
2. @OTRAMM Certainly knows his stuff. I won't attempt to speak for him, but I can offer my own phrasing which I could see being taken as you might have interpreted his input. AHC requires *active diligence* around weight gains. It's not that it's *fragile*, but it does have a pass/fail threshold that conventional doesn't have. AHC can handle a varying load *better* than conventional. Conventional suspension makes it very obvious as it's being overloaded. It tells you right away in very obvious visual and feeling ways. The car will sink and it will *feel* overloaded as you add weight. With AHC, you do *not* get those same warnings as you go. You add weight, AHC compensates. You add more weight, AHC compensates more. All good. The springs rates increase (due to increased hydraulic pressure) and the vehicle height and cornering response remain pretty close to original. You add enough weight and finally AHC hits the pressure limit and says, "sorry, you're over-limit". When this happens it fails to go into H or drop to L from N. It's the *same limit* conventional has, AHC just dealt with the variance *better* than conventional until you got way, way over the intended range. This action of AHC telling you that you're finally "over-limit" is what gives some people the incorrect perception that AHC is weak. You can reset the system's load carrying range by adjusting the torsion bars and rear springs. In that sense AHC has no "weight limit". That said, everything is easier if you keep weights as close to factory as practical.
3. Torsion bars and springs. You definitely do NOT want to use any of the common aftermarket springs for non-AHC vehicles. At least not at first. They will be WAY too strong unless you have a very, very heavy vehicle. Before you jump into possible spring replacements for the rear or torsion bar replacements for the front, you need to figure out what weight you're adding. The ARB bull bar is *heavy*. You can run that if you like, but I encourage you to look at the aluminum alternatives that offer similar protection at a fraction of the weight gain. My Dissent aluminum front bumper barely weighed more than the OEM bumper. The weight gain was almost entirely in the winch. I think the ARB bumper is a full 100-150 lbs heavier than Dissent. That's not a helpful thing.
Spring progression:
Front Torsion bars:
  • AHC torsion bars (<- I'm right here, even with full aluminum armor, a winch, group 31 battery up front)
  • Sway away custom bars
  • non-AHC torsion bars
  • Other aftermarket torsion bars for the 100
Rear Springs
  • AHC Rear Springs
  • King Springs
  • King Springs plus spacer (commonly 30mm) (<- I'm right here and have neutral pressures just below spec)
  • non-AHC Rear Springs
  • Other Aftermarket Rear Springs
4. With AHC, ride height never changes as you add weight. That's the beauty of AHC. It is constantly measuring ride height and adjusting the vehicle to sit at the neutral height. Doesn't matter if you have 1 person or 6. Doesn't matter if you have a stock bumper or that ARB bull bar. The exception is when you drift beyond the appropriate neutral pressures - IE the pressure required in the hydraulic system to get the car at N height. Thankfully, this is *easily* adjusted. Plug in Techstream or a CANbus-capable OBD adapter with a phone app and crank your torsion bars or swap out rear springs.
Since you're new to 4x4 vehicles and the 100 platform, take a step back and go slow. It's a very capable vehicle without bumpers or a lift or even big tires. You know what's much more important that any aftermarket gear? Maintenance. Simple maintenance. Bushings. Fluids. All the boring stuff. You know what costs a lot? All that boring stuff, haha. CV axles are ~ $1500 per side to pay a competent shop. $600-750 if you're DIYing it. Driveshaft is like $600. My simple little water bypass gasket ended being a $1500 job with me doing all the labor in my already-fully-equipped garage.
It's tempting to bankrupt yourself in gear like sweet bumpers, Air Down Gear Up storage systems (shameless self-promotion :P ), skid plates, etc... but I suggest you start simple and see what changes make sense as you go.
If you remember anything though: you don't need a lift.
the stock height part with 750-800lbs of pay load added to it after equipment and myself
Edit: yotaMD explained that’s not a problem with AHC so my concerns are allayed
Spring progression:
Front Torsion bars:
Rear Springs
  • AHC Rear Springs
  • King Springs
It's tempting to bankrupt yourself in gear like sweet bumpers, Air Down Gear Up storage systems (shameless self-promotion :p ), skid plates, etc... but I suggest you start simple and see what changes make sense as you go.
That is awesome advice thanks for taking the time to do that.
We did baseline it as soon as I got it it. $4500 in parts in labor for everything that was done and when they install the bumper we are doing an ahc flush and spark plugs
The land cruiser specialist I work with specifically recommended not doing the AHC mod “because it stresses an already fragile system”.
Fragile enough to concur Rubicon though.
116263653_988659171582133_8746975484245670471_o-jpg.2392518
More pictures here.
That's a lot of weight -
My previous 100 series had a 2" lift with Dobinsons Springs and Torsion Bars. The rear springs were 200kg rated and I had Airbag Man rear bags for the odd time we were fully loaded plus a 200kg draw bar weight trailer. Front armour was TJM Outback bar (about 85kgs/188lbs). It was an offroad weapon, having done the full Cape York Old Telegraph Track including Gunshot Creek and Nolan's Brook.
Current Hunjy is an LX470 with AHC. It does what our previous one did - just better. For the extra load up front, the torsion bars needed adjustment (see YotaMDs video you referenced earlier), and for the rear the King Springs KTRS-79s are the ideal balance between good ride empty and being able to handle full load + trailer.
And on K'gari (formerly known as Fraser Island), the AHC is significantly better in soft sand than the conventional setup.
600lb is half the total payload before AHC will default to low mode. The arb winch bar is 260lbs, the rear drawers are 100lbs, plus full size spare weight and cargo, then myself and possibly a co-pilot, it’s liable to be over 600lb. One benefit of the land cruiser with regular suspension is the payload is moved up to 1600lbs. Ahc is rated for 1200lb, according to the owners manual.
More pictures here.
I’m just going off of what they said - they do seem to be rather conservative with modding.
I looked at dissents offerings last night and I’m sure they are great products, I don’t like the look of it proportionally. The arb winch bar is indeed 260lbs before a winch. I also looked at Slee bumpers and they are more than I want to pay. Being that the arb winch is the way I want to go, I’ll get the AHC serviced before that goes on, we have no idea when or if the fluid was even changed in it. I have the tech stream cable now, delivered yesterday, so I suppose I can look at the pressures to get a baseline before any weight is added. I live in a townhouse with a slightly sloped parking lot but I can go to my folks garage where it’s level. Have you ever run tech stream off a Intel MacBook Air running a VM of win7? It’s the only laptop I have.
Thanks for explaining everything. i like your key holders, I’ll go buy one in appreciation of your wisdom.
Are you referring to a deluxe bull bar?
Idk why info online for this is so scattered, but it's 176lbs shipped on a pallet.
Additionally, if you're not looking to be mowing down saplings in remote forested areas and you don't live in cow or deer-land, save the weight and get an integrated winch mount for the factory bumper like Trail Tailor. This is coming from someone who has the ARB deluxe bumper and I hate it. There's really very little benefit to having it, it reduces approach angle, and unless you're also going to spend $3-4k on a rear bumper, it looks silly and bucktoothed on our trucks. In my opinion.
this increases approach angles, called the winch bar according to Slee and it’s 260lb: ARB Winch Bar - '98-'07 Land Cruiser. - Slee Off Road - https://sleeoffroad.com/products/3413190/
Edit: you maybe right about the weight because lower on the page after 260lb it says 160lb. That’s great news actually if that’s the case. Now I’m positive I want it
Approach angle on this bumper is not good. I hate it. I'd love to get rid of mine, just need to find an alternative first.
It's around 176-184lbs depending on who you ask. My understanding from ARB Coopers Plains (which is an ARB company store here in Brisbane), when comparing the ARB Deluxe Bar and the TJM Outback Bar, was that it was 80kgs or 176lbs.
The vehicle height cannot be raised if the load exceeds the following limits:
  • 572kg / 1,261lb in normal mode
  • 442kg / 975lb in high mode
(Quoted from P224 of my owner's manual)
And as noted, it's really really easy (index or tighten Torsion Bars on the front, King Springs + optional 30mm spacers + optional airbags in the rear) to optimise (or baseline) the AHC for big increases in static weight. I dare suggest easier than a conventional suspension - the 200kgs Dobinsons rear springs were F I R M when the truck was empty.
Rear draws - they're lighter than the 2 seats I removed to put in.
The posters here have given you some factual advice based on their own experience with AHC and conventional suspension setups. There are members of the 'mud with serious armour on their AHC rigs, who regularly thank Toyota for such a great system.
Good point about the rear seats, them bitches were heavy. I forgot they were even in there as it was the first thing I took out.
I’d like to stay well under the load capacity as I’ve heard other users and you tubers say theirs won’t go into high mode while still being slightly under max payload.
If theirs didn’t go into high then they did not correct the pressures for the load.
The LX470 comes with a lift built in. Adjust your t-bars and use airbags and you can carry more than a regular 100 series LC. I've loaded the rear of mine with over 1500 lbs of ammo and it still goes to high if I have 10 psi in my air bags.
Does everything I want and more.
This is what I would do if I were to do it over again.
And the supercharger.
Just give me your truck.
I suggest you look up OTRAMM then, they are highly respected in Virginia.
Ahc components often last 3,4,500k miles. That’s highly uncommon for conventional shocks.
But to be fair to OTRAMM, they see east coast vehicles at their worst after local shops can’t/won’t figure stuff out so I understand him disliking ahc. Many dealers don’t seem to know much about the system so owners are kind of on their own when they have an issue.
In terms of lift you can to do a 1-2 inch body lift and 2-3 inch suspension lift. 3.5-4 inches total isn’t a big deal.
