You can also spray the carb cleaner at the locations where you suspect a leak. If the RPMs pick up then you have located a leak.
-Mike-
That's how we found the carb and manifold gasket leaks.
-Mike-
This may be a broad question, but how much fuel should be in my bowl when I look through the class. Should that be changing at all?
The losing power after working well sounds to me like a fuel filter (or a clog in the fuel system one way or the other).
Dan
that the ig coil can produce similar symptoms when they go bad. Swapped in a new coil and all was good.
3. Does anyone have a coil, ignitor, and distributor from a FJ60?
Don't forget the engine side cover.
got that too.no worries, it's all in the same box together.
Sweet, you have a PM coming your way.
Alright today has been a good one to me. I got the fuel pump tested and it is only putting out 2 PSI and I think it needs to pushing out 3 or 4. Does that sound right? This would make sense why I can get the engine to kind of idle and then fail after I put it in gear. I have one coming in from Dan. Only 11 left in the world when I ordered, so I am glad I got one. Also if the fuel pump isn't the issue I see it as preventive maintenance.
Also I got the vacuum tested. I tested off the three lines going into the carb.
*Off the line labeled five on the carb. I had 30 with full throttle and 0 at idle.
*Off the line labeled thirteen I was getting 40 with full throttle and 5 at idle.
*Off the diaphragm I was pulling 0 for both full throttle and idle.
Finally I got the carb gasket paper to make up a new gasket for the base of the carb. What is the best way to cut out the circles in the paper. I was thinking scissors to get the general shape of the gasket and then an x-acto for the circles and other detail work.
RIGHT ON dude, good going. Nice troubleshooting steps.
Assuming you have a vacuum advance on your distributor, check to see if that thing can hold vacuum. Sometimes a pin hole develops in the vac diaphragm and you don't get the vacuum advance under throttle. You'll need a vac pump to test it. If you don't have one, you can use mine.
Your idea with the carb gasket making seems logical to me.
