Ummm, I wonder if something is wired incorrectly.
Look at the upper left of this diagram:
IH8MUD.com - View Single Post - Is it possible to down grade from electronic start to points ignition?
You are running fine when the key is in the start position, correct? The only difference is the resistor (the squiggly line) for the run position. Are you wired through that resister? You need to be or your points will not last. You can bypass it momentarily to see if it will run. If it runs, the resistor is shot (open). If it still doesn't run look at the wiring continuity from switch to resistor and resistor to coil.
I think I remember that you replaced the fuel filter too.?? if not, do it.
make sure the secondaries are opening. the second barrel of the carb should open with more fuel on full throttle. you can look down into it and see this when someone gives a WOT (wide open throttle), watch your face that no back fires happen while your head is over the carb.also check that the accelerator pump is in good shape(a plunger in the carb next to the bowl). my FJ45 has an issue with that. give it gas and it dies).
Good morning Paul,
On my 40, I have a stock carb that has been recently rebuilt by Mark at Mark's Offroad... we could do a temporary transplant to see if that solves your problem.
Guy
Good morning Paul,
Guy
That FJ60 is still listed at the U-Pull. It could be another donor. I know it will bolt to the manifold. Don't know about linkage.
