Reading this thred it looks like it need to be a special kind of elbow is this something you can get a Lowe's or homedepot? Or need to order one?
Common brass fitting available at the Lowes, HD, or any hardware store
Sweet thank you!!!!!Common brass fitting available at the Lowes, HD, or any hardware store
Can couple of you with this compressor run a time test for me on a set of 315s? I'd like to know the time to go from 15 to 35 PSI with a fully charged/pressurized air comp and the engine running.
Thanks.
Based on 100+ times using a stop wtch
At sea level, 85°, 1400 rpm 2 minutes per tire.
The first tire would air with slightly lower time if started with a full tank.
Umm, you didn't record the humidity and the barometric pressure? Loser.![]()
Thanks.
No real need to regulate output. Many remove and add a 90° fitting to keep things streamline.
My recent LX470 PUMA mount in progress.
Compressor arrived today. Need to get a good hose. I'm not going to mount it in my 80. It will be used in more than 1 rig, so going to fab up a power cable. Trying to decide whether to go with good clamps or fab battery harnesses with high amp quick disconnects - like they use on computer battery backup units (UPS).
Yup, those connectors are exactly what I had in mind, Phil. Thanks!A nice solution is to purchase #4 jumper cables and remove the clamps from one end crimp on some Anderson quick connects to the compressor and the open end of the cables and you are ready.
I've read a lot of this thread, but couldn't decide what the advantage is for a divorced tank or just removing tank. Is it just for space savings? It would seem that keeping the tank would keep it more flexible, like for OBA (ARB lockers) or air tools.i separated my tank, but the hookups I used are what you describe in my post #143.
Can someone please educate me (in dummy terms) about tank vs. no tank? I've read some posts that suggest that tire fillup might be slower with a larger tank (or the double tank model) and that the tank is mostly useful for running tools. Would I be better off just using the compressor without a tank in the interest of saving space? My primary purpose is just for airing up tires for now--no air tools in the truck yet. Speed of fillup is priority #1, space savings is priority #2. I don't really understand the technical aspects of compressed air.
@Blue77FJ40 how long does your compressor-only setup take to air up? Are you running 265 tires on the tacoma?
