Projecting, tinkering, fiddle-farting around: whatcha building? (5 Viewers)
So... I've been dodging this project for the past two years, and I'm getting tired of seeing it sitting (and taking up valuable space) in my basement shop.
T92 transmission:
I originally bought it with the plans to convert my single transmission Economy Power King 1614 to a dual transmission. The above pic shows it bolted into the necessary driveshaft tubes. The primary transmission (also a T92) goes to the right (ahead of it and attached to the front tube).
After tearing into it (I can't seem to leave good enough alone...), I discovered a number of things:
1) It was originally a Crosley automobile transmission, as it had the speedometer gear setup.
2) The main case had a few cracks.
3) The gearshift lever had been cut, shortened, and re-welded to simulate the one used on the rear Economy T92.
So... I did disassemble everything, sandblast/paint the top cover, clean/inspect all the 'guts', and there it sat for over two years:
During the two years that past, I managed to source another case, which was from a tractor. And it was in excellent condition. But it also sat on a shelf, along with a rebuild kit for the shifter housing, their fates not yet determined.
Continued...
T92 continued:
Over the past couple of years I did source a pair of T92 transmissions for my Economy Power King:
So now I have a total of four transmission (including the one currently in the tractor). I figured I'll just get the converted Crosley back together and prettied up:
Sourced new ball bearings for the input and output shafts, painted what needed to be painted using Rustoleum Lobster Red. I let the paint cure for two weeks, then over the course of a couple days put it all together:
I decided to go with the two tone paint scheme, even though it's not OEM for the Economy PK (with would be a solid orangish/red color). I also got quite good at assembling, disassembling (can't get the main shaft in with the rear bearing installed), assembling, disassembling (put the reverse/1st gear in backwards...), and finally assembling it.
I'm waiting for the shift boot (it won't be the correct one for a rear transmission, which seem to be unobtainium, but one for the main transmission), then it'll probably go up for sale, as I think I've got enough T92's right now.
New hatchet. Sanded, wire wheeled, stained, blued and oiled the blade. Next we will put in a container for about a week full of tung oil to saturate the wood. I ordered a buffalo sheath off Etsy for it.
Soaking in Tung oil.
Last of the T92 project.
I decided to fabricate a stand for the T92 transmission:
Used up some of the 60 year old 3/4 plywood I had from tearing apart an old kitchen cabinet. Sanded all the old varnish off, wiped on three coats of gray stain followed by three coats of poly, and a final coat of Johnson's paste wax.
I built two of the stands, to be used later when I rebuild/restore the other two T92's, that are waiting their turn as a part of the larger Economy Power King 1614 tractor restoration.
Going to try and sell this one (without the stand), on MarketPlace over the weekend.
View attachment 2975926 View attachment 2975928
I've been putting together a stand for a recent tool purchase:
  • Took a truck brake drum and welded a VW rotor to it. Then turned down a second VW rotor for the lug holes to line up.
  • Welded an upright to the second VW rotor and bolted the two rotors together.
  • Turned a fitting that would fit in the upright and welded it to the tube clamp.
  • Painted the drum and rotor and powdercoated the rotor and upright. Drilled through the upright and fitting so that a hitch pin would lock things in place.
  • Provides a nice solid base for a Tinman's Garage Planishing Hammer.
  • I put a disconnect on the airline at the hammer so that I could easily swap things out.
  • And, finally, a closeup on the tube clamp assembly.
Next step is working on a storage unit for the dies and hoops.
have 2 broken shovel handles and one 'trench' shovel head (I think it's actually a cut-down spade head ;) )
I finally got around to gravting the head to one handle...
modded the mini camp mattock/tent stake pounder I'd previously fobbled from rusty pipe and a trailer leaf spring
added some ballast
gave the head a bit more digging power
Zero investment shade alley for bikes; Dead space between new fence and existing shed. Reclaimed suntarp, reclaimed gas pipe. 🤣
Buggy rollcage action.
Feeling pretty good about these welds.
