UPDATE
Ok, so here's an update. I got the system at least up and functioning for my bachelor party weekend run up to Big Bear last weekend.
I ended up getting the Slee bracket, as I needed to have the system up ASAP and Lumpdog still hadn't finished his kit. I'm going to still check his out when I can as I think it is a nice kit as well.
The Good:
- The system airs up very quickly - not much more than 1.5 min for each tire from 20psi to 35 or so. I was running at idle as I haven't installed a hand throttle yet.
- The Slee bracket doesn't involve relocating the metal heater line and was easy to install. The unit DID NOT have tensioners built in, but I was able to tension it with Mr T's OEM jack underneath pushing up from the frame rail. A little elbow grease to get it in line with the new tri-groove pulley. Installed with a new belt (I'll upate with the part #) and the setup is squeel free (with a new belt).
The Bad:
- The bracket doesn't tilt the compressor enough to match the slant of the engine, so the belt from the compressor to the main pulley is a little twisted. This may have been on purpose though, as the belt is within .5 of an inch of the front of the engine block. My first belt installation squeeked, but it was an old belt, so I got a replacement that was the same length but as skinny as I could get it. That belt is much quieter and seems to ride in the grooves better, even with the slight twist.
- Oil, oil, oil! The compressor spews oil, and I stayed on the low side of the York recommended amount (only about 8oz of oil in there right now). There was enough oil that I could see visible oil bubbles where there was a slight leak in my system. I did not have an oil/water separator installed for first use, so my tires have a bit of oil in them right now, but this will be fixed when I install one.
- Leaks! Make sure if you use barbed fittings that your clamps are VERY tight - I found about 3 leaks in the air system where clamps that I thought were tight weren't tight enough for the 150PSI system. Not a huge deal to track down - just use your ears and some soapy water.
Overall (Slee Kit):
I like the Slee kit, but I wish it lined up a bit better. Other than that, it is a great product, especially at the new and improved lower price. However, I was hoping a belt would have been part of the kit to make the install easier. Still, easy to obtain.
Overall (York System):
I am very happy with how this turned out. Once I get an O/W separator I will be much happier as I won't have to worry about filling my tires up with oil! The sytem airs up faster than any other unit I have used. One word of advise... get a screw-on tire chuck if you can - the clip on ones (at least the cheapo one I got from Harbor Freight) have trouble staying on at the 150psi system pressure. I'm still on the lookout for a screw-on type connector to complete the system.
Please feel free to ask any questions or want more pics!
-Phil
Completed system with Slee Bracket:
Pressure switch in front of the battery. I've got to find a better way to secure it!
Bracket Detail:
Belt Detail - notice the angle difference on the belt:
