Watch that bracket. Mine cracked right where your (red) clutch wire runs over your bracket.
The Bad:
- The bracket doesn't tilt the compressor enough to match the slant of the engine, so the belt from the compressor to the main pulley is a little twisted. This may have been on purpose though, as the belt is within .5 of an inch of the front of the engine block. My first belt installation squeeked, but it was an old belt, so I got a replacement that was the same length but as skinny as I could get it. That belt is much quieter and seems to ride in the grooves better, even with the slight twist.
I have been dying to get my hands on an adjusting bracket. Lumpdog was supposed to be making one. Then someone else made one but didnt make the specs available. I haven't ordered the Slee one ONLY because I want an adjustable. I am thinking now I may just need to say screw it and order it![]()
Phil,
I'm not clear what you mean here and I can't really see what you are referring to in the last picture of post #140. Are you saying the Slee bracket is such that the pulley on the compressor does come out to be parallel to the crankshaft pulley?
NLXTACY said:Ugh, does Christo know about that? I am just about to pull the trigger but would hate to find that little surprise waiting for me after being installed.
I never contacted Slee. I ran it for about a year (since the install), prior to discovering the crack.AppleTech said:Yeah, did they replace it for you? The welds on mine look beefier than the ones on your bracket... perhaps a change in design?
I probably should take it off.
I guess I just prefer sleeping to working on my truck
