If you have the 6" diameter pulley, you should need a Gates 9570 belt. I have a 7" pulley and am running a 9580 belt, which makes it sit just a tad to high, but is ok now. At the time all I could find fast was a 9580 and 9570 belt. I have ordered a 9575 belt now, so when I put the York back on after all the test fits of the new brackets, I can put the new belt on and have plenty of hood clearance.
Trailbus was right on the money!! I prefer the 111 and 112 just because I like JIC fittings, but 113 and 114 are probably much easier to work with. Personally, for the suction side I would use the JIC fittng (112)adapted to your filter with a 45 degree JIC adapter to pipe thread. Then on the pressure side use the hose barb (113) so you can clamp your high pressure hose to it.
(JK lumpdog! ;p), I was wondering if I filled up my tank with air if it would be enough to air my 33s back up from 15psi or so to 35 psi (4 of them)?
