Looks like you tried to recess the PS box a little more. Was there a reason for this? Looks fairly easy. This mod is on my list. Thanks for the pics.
Lookin AWESOME!
Im itchin to get to this part too.
So you were able to squeeze a 19x 26 in rad. up there?
Interesting. I ended up with a 19x24 griffen. Planning on the Mech. fan as well, but have a taurus fan for back up. With the Vortec, the upper rad. hose is in jeopardy with the fan the way it fits...I may end up having to drop my rad. supports DOWN for better clearance.
Nice seeing this part of the build!
Nick,
I have been reading your thread for quite some time. Very impressive. I have learned so much about the amount of hard work that goes into the 40. Keep up the great work. I wish I had your talent and ability to put so much of you life and dollars into a machine like this. Awesome!
Jonathan
) Borgeson 014940, Summit Part # BRG-014940. My Flaming River 1" DD to 3/4" DD column to shaft joint worked like a champ. I bought a 36" 3/4" flaming river DD steering shaft and it is plenty long, I will probably end up chopping off about 7" or so. I drilled some countersunk holes to allow the bolts on the u joints to sit in.
I also picked up my rear driveshaft today from Automotive Driveline in Hurst. It took a little test fitting of the flanges before this thing was fabricated because I have the stock TC but a 78 rear diff, so my bolt pattern on my diff side is different. I measured about 18.5" inches from flange to flange.
Compressed:
Extended:
Nick
This the little place on 10? and how much did it run you? been wanting to get my rear driveline on the 60 redone... again...![]()
Yup, thats the place. It was $300 plus tax so about $325 out the door. I still have to have my front shaft made now but am going to drive the cruiser up there for him to look at it because my 700R4 tranny pan is close to my front TC flange and want to make sure it is made to clear the pan.
Nick
Nick,
Jim from Downey and I talked about this clearance issue before. He has (or had) a small diameter flange/u-joint made for this purpose. Give him a PM, he may still have them.
Steve
Nick
OUCH! seems like alot... but it looks like he made it all from brand new stuff and didnt re use any of the old shaft at all. is that correct? if so then if he uses my ends and re tubes it it should be cheaper ish. last time i had it done (twisted stock rear shaft all up) it as like a bill.
Nick,
This is an AWESOME build thread man! Youre doing a GREAT JOB, and making this for a good reference. I cant wait to get back at my 40. The wife informed me that we were NOT going through another summer without the landscaping done...soooo, Im a landscaper for the time being...![]()
is happy! Should be able to get mine on the road, at least for a test run.I've been wondering where you went. First things first, make sure theis happy! Should be able to get mine on the road, at least for a test run.
I've got to get my pitman arm and new draglink.
Nick
LOL...Just got back from an annual Death Valley run. Prep for that has taken a bunch of time running the stocker down there.
Where are you gonna source the pittman and drag link?
