Project MOVIESTAR
Fantastic work...Are you adding a drip rail to the roof?
Ah, yes. This pig will have a roof rack. What I plan to do is make new rails out of heavier gage steel. And then possibly reinforce the mount points further. I will be sure to document that when I do it.
Awsome build:clap:........inspiring as was your first one......BTW; do you know what media was used for blasting?...have been afraid of warping; also; nice patch work on the doors.....did you mig it? or use OA?........TIA
Lou
Do the A-pillars of that pig have a lot of lead in them? My pass. side comes up almost to the top it seems. Unless I'm totally mistaken??? I'm thinking for that corner section I'm gonna have to JB weld it since I'm leaving the glass in as well.
yes, quite a bit of lead. I took the torch to it to find the original welded seam. (still have some of the solder in my bootlaces)
That will be tricky, with the glass in, but there are products on the market that bond metal to metal without welding. (I have never used them, but have seen the work, at it seems fine) Might be worth looking into.
lou-sorry i missed the media blast question. Tracy uses sand in his blasting booth. He is very careful to watch the heat buildup and warping. If a panel seems to thin, he will had sand the center, and just blast the edges.
Since we finally got above 0degrees, I got back into the garage today. (fun facts: air compressor lines freeze when it is below 0, and auto darkening welding helmets don't work right below 0.) Guess which two things I really needed last week?
Mostly I did an hour of finish weld and grind/shape on the drivers rear wheel lip.
But, I also thought to do a little modification I thought would be nice.
I took the interior light from Frank, cut it off, flipped it around, and put it above the cargo area in the rear. Relativly easy with the roof skin off. (I imagine this could be done with the roof on, and the headliner out)
Nice work Jason
fj55 Rear Cargo Light
So you're going with TWO lights?! Stock location and then the new one in the rear? I dig it, that's brilliant. :)
Yep. I always thought cargo areas were too dark. My 64 Fairlane Wagon has a rear cargo light, so I was looking at it, looking at the empty socket on Frank...
Seemed so obvious, I wonder why the factory never did this?
Also, the pics of it were duplicate, I fixed it so there is a different angle. All the welds are accessable from inside/under, so this would be possible to do with the roof skin on and headliner out.
I did the same thing on mine. I just have not yet put in the second light. I was going to have them both work together since the second light I have doesn't have the little toggle switch.
What I also did was add the extra bows from the second roof so rather than just two or three bows to support the roof I now have twice as many. If you are careful in the placement you won't see it through the headliner.
I notice my dome light has three positions - I wonder if you could take a light with the broken lever and put it in the rear and slave it off the front light with lever?
That's my plan. Maybe I'll look into that tomorrow.
Three positions being Off, Door, and On? It could be wired up a couple different ways.
1. Independant. Works just like the front one. (Off, Door, and ON)
2. Fully Slaved. Matches what the front one is doing always.
3. Partially Slaved. Wired hot ONLY if the front one is in one of the On positions, but with its own switch, can be turned off independantly.
It is kind of a preferance thing. I guess I better ask Elyse how she wants hers wired up.
Last driverside roof patch got put in last night, pictures soon. I started on the drivers rocker panel, but the 20 minutes of sand pouring out of the first cut made it hard to keep going! Ever run an air tool in a pile of sand? Don't. You end up eating a lot of sand.
Great visual!
Let us know what you do with the light...
I was wondering if you could wire the lights so the Door position up front turns on the rear light?
I am just thinking the rear cargo light option sure would be awfully convenient. Especially at the drive-in movies, camping, etc. I will be replacing my headliner soon, but I do not have a spare light mount or a spare dome light.
1. Independent. Works just like the front one. (Off, Door, and ON)
3. Partially Slaved. Wired hot ONLY if the front one is in one of the On positions, but with its own switch, can be turned off independently.
It is kind of a preference thing. I guess I better ask Elyse how she wants hers wired up.
One problem though. '55's do NOT have door switches, at least mine doesn't (they could be added though)!!
I figure I'll wire it from the front light to be either front only, rear only or off. My extra dome light has a broken toggle switch so I cannot control it from the rear.
Better yet, when I replace my headliner later this year I can wire it to a relay from the rear window lockout switch so that when the tailgate is open the light comes on.
Jason,
Does that hole in the B pillar look like a mount for seatbelt?
Good Idea also. Make that 4 ways!
Jason,
The hole directly above it? That is a headliner bow hole. BUT, if you move back alone the roof support, there is a factory mount point above the rear cargo windows that has a factory threaded hole that is the same size/thread count as a the point for the front seat belts. It was totally covered by the headliner, but given its position, and bolt size, it almost has to be designed for a seat belt point.
I will get a picture of it tonight. I imaginge you could find it with a good measurement.
