I seem to recall seeing that pig in the Silver lake area some time ago
Good job on the fixing
Center dash removal is much easier if your heater box is out. Not impossible with it in, but easier. Early models have some access, later models, you will have to remove the upper vents at least. You do not need to remove knobs or switches, it is much easier with the whole plate out.
1. disconnect choke cable at carb.
2. remove radio (i have only found aftermarket radios, always hack the dash the same, makes a nice access hole)
3. Remove heater control cables. I find this to be easier to do at the end, rather than the controls. You most likely will have to remove your blower box to get one of them off. This is still easier than trying to fit a very small phillips head inside the dash, upside down, with nowhere for your hand to go.
4. unplug any electrical connections that you can get to.
5.remove the 6 phillips head screws from the face plate. Some of these might be covered up by the aftermarket radio sleeves. another reason to take radio out first.
6. The face plate should come forward some now. You may have to help the heater control cables along the way, and disconnet wires from the back side of the center dash plate.
7. Once all wires and heater control cables are disconneted, radioe is removed, and choke cable is free. Begin pulling the face plate out.
8. Even with everything disconnected, you will have to maneuver the plate to clear the levers behind the heater controls. Do not force it, the plate can bend easily. (see photo for the offending lever)
9. Reinstall is easier the reverse, except I usually install the radio adaptors first, to make it more secure.
a photo of the back side of the center plate. This is from a 73.
a photo showing the drop down lever that has to clear the dash.
catagory. A little exploration with a wire wheel showed tons of fun. And by fun, I mean bondo. The body looked great, with a little bit of rust bubbles, few dents. Well, no. When the body work was done, no effort was made to pull dents, or fix rust. They drilled holes to anchor the bondo, and squeezed it into the holes. Sloppy, cheap, but it held up for 10+ years. The bondo was so thick in some of the rust holes, it actually prevented the rust from spreading.
All I can say is thanks to this forum this pig is in good hands now.
