What are your thoughts on that 4 runner frame, it looks darn near a perfect fit after you trim the rear length. Does it seem like body mounts will be reasonable to make work?It’s been a minute since I’ve posted on the build. Been gathering parts and cleaning up the frame
I love it. Body mounts are gonna be close to the frame. I think it will work out perfectly. The rear frame will definitely need cut off and the rear bumper from the 40 fits on the frame perfect also.What are your thoughts on that 4 runner frame, it looks darn near a perfect fit after you trim the rear length. Does it seem like body mounts will be reasonable to make work?
Do you start with coilover uptravel (exposed rod length)? Or do you decide ride height and make the coil fit?So with the new frame, I’m trying to figure out ride height.
It has a 98 4Runner frame, Dana60 front axle, Sterling 10.5 rear, Atlas, 3-link front, double trianglated rear, 17” rims with 40’s, and King 2.0 16” coilovers
Center of axle will be dictated by the size of tire . Not a chance you are getting 16 inch coilover in Under the hood 14 is doable . FWIW i run 12sDo you start with coilover uptravel (exposed rod length)? Or do you decide ride height and make the coil fit?
Centerline of the axle is 20” theoretically but will be more like 18”, and if you can mount the lower end of coil even with centerline of axle, plus say 5” of rod showing, the top of the coil will be 31” above center of axle. Plus the 18” puts top of coil at 49” high. Hood or fender will be above that (or tub will be that high).
Match all the body lines/mounts and that would dictate ride height, right? Or did I do it wrong?
I know on mine I have worked really hard to get it low enough to step in without a ladder, and high enough to be a respectable wheeler. We’ll see how the compromise works…
I thought 16 would be tough as well. I’m 12 up front and 14 back.Center of axle will be dictated by the size of tire . Not a chance you are getting 16 inch coilover in Under the hood 14 is doable . FWIW i run 12s
I was setup for 16” shocks on the front with 5” of up travel. I lowered my shock mounts and switched to 14” coilovers due to availability at the time and I am glad that I did. My current down travel is more than adequate for me.I thought 16 would be tough as well. I’m 12 up front and 14 back.
He said he had 40” tires so that’s where I came up with 18” to cl, and that’s if the tire is true to size at all.
That looks sick. How big is it? Pretty fine lines to get out of a plasma unless that thing is the size of a full sheet.Made some wall art awhile back
