Build Project Lockjaw-1973 Fj40 on Tons
Body is resting on the new to me frame
Looks more like a tundra frame?
Definitely not a 80 Frame 😎
What are you up to and what vehicle did the donor frame come from?
I am reusing my engine, trans, t-case, and axles on the new frame.
Are you going to use the same drivetrain in the 80? frame?
Not an 80 frame 😆
Tank5 you are the closest to guessing what it is.
The frame is from a 1998 Toyota 4Runner. It is a lot wider in the front end and will help with packaging everything I want in the front. WFO Concepts sells everything to SAS a 4Runner/Tacoma with a Dana60. It will still be a 3-linked front and a double triangulated rear 4-link. Same body that I started with.
Not an 80 frame 😆
This makes a lot sense as WFO has done all the homework already and you know it’s all going to work.
Let the front suspension rebuild begin. Got in a few of the parts I ordered from WFO. The body is just sitting on the frame for now. Got new frame side motor mounts in.
Did you buy or fab the cross member? If bought, WFO? Did not see it on their website
Yes, it’s a crossmember with built in links. It’s for a 3rd Gen Tacoma or 4Runner. My new frame is from a 1998 4Runner.
The new transmission cross member with built in lower links for the front 3-link is beefy
I’m getting excited about the project again. Can’t wait to start welding stuff on this frame.
Old trans crossmember cut out and frame smoothed out
Well I got the body back on the frame today. If I place the engine in the stock 4Runner location, I’ve got a ton of room in the engine bay.
