He was prob running Petro Canada Diesel
Ah yes, I see many little things there one might not consider when compiling a list for a diesel swap.
Thing of it is..... no smoke. Not even at red lights. Go figure.![]()
There is a captured nut insert.
Please elaborate...
Something like this.. Should be a bit stronger than the original nutserts that work on thinner metals.
http://www.rivetsinstock.com/rivet-nuts-threaded-inserts/threaded-inserts.html
Hmmmmmm..... do you really think those will be strong enough to hold the transmission?
We did a few diesel conversions and used this method with standard old nutserts as per Kurts advice from Cruiser Outfitters and never had a problem.. The units I posted up are a much better and stronger option, I am pretty sure it would work...
Kinda like those concrete anchors...
I like the idea of a fender washer or maybe a couple of 3/16 piece of flat bar with a hole drilled in it about the size of the nut, weld it to the flat bar..
If you cold find a nut that is a big longer say inch and a half would work best.
Make the hole in the frame a little bigger than the nut and weld around the nut to frame from the bottom. Finish by running a tap through the nut as the heat will of distorted the nut a bit.
If the flat bar or plate is the width of the inside of the frame and a few inches long you could probably drill a small hole on either side of the frame and plug weld the flat bar to frame?
Not sure if this method would work.
But check out the powder coat on my rear bumper!!!
That had better be a bottle opener![]()
I might have to buy that 80 I mentioned at the pub and do the swap, auto tho...
Rob
Looking good, where did you get that bumper powder coated. I'm sick of black!
