I have been working on fitting a York on my 1HD-T while retaining A/C. So far I have the bracket made to hold the York flat against the head. It is very tight!!! You have to get the top two bolts in the bracket before you screw on the bracket. And you have to take the oil cap off to get a wrench on one bolt. I was not able to fit the fourth bolt, so the York is only held with three.
I brought the plate up high enough and put a large hole in it as a lift point if I ever need to pull the engine again. The original lift point is gone with the original A/C bracket. A person could remove the York and A/C and re-install the original mount to pull the engine but... it would be a matter of finding said mount in 5-10 years in the basement, etc.....
The A/C pump will mount to the outside of the York, and it will pivot to tension the belt. Once I get everything lined up and working, I will try to add some supports under the York so the body of the York isn't carrying all the weight of the A/C compressor.
A/C lines to the compressor will most likely need to be modified, but I have to modify them anyway since I have an R12 condenser going to an R134a compressor... (That is in an effort to get the R12 receiver/dryer location beside the battery.)
I'll post up my results when I get the A/C bracket made in the next week or so.
This tab is re-inforced from behind with a perpendicular piece of metal.
nice work new you'd do it.
