Texican
s-Moderator
Hey Russel, how many cover bolts do you need for a 14 bolt cover?
I did not post it............
Butch
Russell, are you still towing with the single axle 2500 Chevy?
Jim A and I went to Phoenix this winter with my buggy and his buggy on my 29+4' Gooseneck pulling with my 2500HD Duramax 4x4 Crew.
With my camping trailer on the front and all the camping gear on the gooseneck, the gross load was 250# shy of the max listed in the owners manual.
Reason I mention this is that Big Tex probably weighs as much as Jim and my buggy combined.
You may want to play with the loads a little and load Meanie on backwards and Tex on the rear just to put more weight on the trailer and off the rear axle.
The real limiting factor is the single rear tires. May not be that big of a deal to you, but I thought you might want to run it over the scales sometime to make sure you are OK.
Yes, same diesel 2500 Duramax PU. I loaded both on the trailer and went to Clayton a couple of weeks ago with no mishaps but you have a good point, and one that I have not considered. Thanks.
RA![]()
I'm all about the limit strap on the ATV winch!!! I use that same winch in the rear with my 4link to control the suspension, I'm going to try that out! How did you attach it to the drum?
Jason
He only used it a couple times then sold it to some lucky fella in Cali.![]()
