Okay...starter replacement is done. I also went ahead and replaced the intake manifold gaskets since I am at 210,000 miles even though they looked good. Some thoughts and lessons learned:
- the writeups here were great...some things I either did not read or were missed but for most part was good help.
- Make sure to take pictures of both sides and front...before removing intake manifold and any hoses or plugs.
- Make sure to have plent of rags available to stuff into the 8 ports
- Rats do in fact like living there....I found nesting material and a bunch of dog and cat food. Was not from me since it is daily driver but may have been from previous owner..who knows. Rats were gone but shop vac got all the stuff up.
- There is a quick disconnect for the pesky electrical ground at back of manifold...comes out of firewall on DS slightly above engine...black clip. Much easier than trying to get to it to remove from back of engine.
- I folded throttle body forward and did not disconnect anything else from it after removing air box, maf sensor, etc...just let it sit forward.
- I did not disconnect any fuel lines or rails....when I got the bolts, hoses, throttle cable and a couple mounts on DS loose...when I lifted manifold I just layed it upside down sort of and had blanket there to help support Allowed me to wipe underneath of intake manifold ports and not mess with fuel lines or anything.
- There are two plugs about mid ways in the lower part of motor with wires going to them...they are knock sensors. Be sure not to touch or mess with them as they can be brittle. I was warned by my shop locally so stayed clear.
- Wish they would have warned me of the two plugs just behind the water pump shown in picture below. They are the green and the gray plugs to left of water pump housing I think...I believe the one is the ECT Sensor and the other is the Water Sender Gauge.
This is not my engine....I used red rags but the mouse nest was similar minus I had much more cat food piled up.
Anyonw...careful when moving it around as these will snap easily after 210,000 miles on a 2000 LX470. LOL
- Removing the engine hook on PS of engine is a big help...but cannot remove hook on DS for two reasons...one is it is used for a ground wire and the other is one of the bolts goes through to engine and will allow oil to blow out unless you replace the bolt and seal it. That one stayed in place but did not prove to be much issue.
- After reconnecting everything....plugs, hoses, wires, etc......truck would not start for a bit...starter worked great but would not fire and run. Guessing it was MAF and fuel system having to re-pressurize. After sitting for 5 hours with no battery power...soon it started idling and running fine minus the inop water temp dash gauge.
Some words to wise--
- buy a magnetic wand for sure...that thing is a life save in retrieving the bolts from intake manifold and the nuts as well.
- try to source magnetic 12 and 14 mm sockets...but if not take some thin box tape and put in the socket head and it will hold your bolts and allow you to drop them into the holes and tighten...then can remove tape from head of bolt if needed with the LONG needle nose pliers.
- have shop vac ready to suck up all the loose stuff...my whole engine was covered with sand and debris
- pop the two hood struts and then have a sturdy item to prop it up and someone to watch as I hit it a few times with my back jockeying my 6'3" 250+ lbs in engine bay. LUckily my large bumper allowed me to stand on it and also a step stool for over fenders...would have been easier to remove front tires...and lower onto jack stands to make easier to reach.
- Be careful to pull away and tuck all the blue connectors to make sure none get crushed when putting it back together...tuck them good.
- GET A FRIEND TO HELP even if it is only for replacing the intake manifold....the 2x10 or 1x8 someone recommended would have helped IMMENSELY if I would have seen it prior to starting.
- Dont wait too long after it starts acting up...mine started last week...woke to 37* so swapped cars in driveway with intent of backing it into garage so I could run heater and keep warm. It failed to start after wife misunderstood me saying back it up and thinking I only meant part way up drive instead of into garage...it was dead. Thankful she was not stranded during week or did not happen elsewhere but was a chilly morning.
** Was it worth doing it myself rather than paying $400 of labor for my shop to do it?
- when I was fighting with the manifold trying to re-install...no I would have gladly paid the $400...not kidding. LOL
- now...glad I did it so I can help others....if someone had been there to guide and show me it would have went much smoother...so now I can be that guy for others that may need it soon.
- my only regret is not getting help earlier so I may not have snapped off the water sender and ECT sensor with my brutish attempt to do everything by myself. LOL
Thanks to IH8MUD once again for helping me figure out something and do it myself...from desmogging my FJ60 a few years ago...installing Aussie Lockers with help of friend....and more. Well worth it to me.
Thank you everyone....
