OTRAMM
Supporting Vendor
I bought one of theses daytona jack. It's been great. No issues in 3 or so years of use.
Thx Ryan I’ve wondered about the harbor freight jacks. Does it lift cruisers with adequate clearance?I bought one of theses daytona jack. It's been great. No issues in 3 or so years of use.
I would still skip the brake junction and go with flexible hose straight to the caliper. It makes axle and brake work easier, in the long run.Ok, maybe I’ll keep her all stock with the newly restored backing plates then. Once I finish cleaning up the diff and the calipers then I’ll start reassembly, probably tomorrow.
I really like my HF US General toolbox. I was told they are made from an older SnapOn model. It’s heavy duty! Ask @Tikicruiser and @Stumpalama they helped me move it last weekend.I just picked up a set of aluminum jack stands from HF and their lighter weight is much nicer to deal with. I used to be anti-HF but some of their products have been getting much better and they’re low prices are great for those infrequently used tools.
I did a lot of research before buying my new toolbox and HF’s US General line came out on top for quality vs price.
Yes, this 10X. I bought one as a 2nd jack/replacement for my old Pittsburgh. I got the low profile, long reach jack. It Jack's up 23" and gets my sprung over 40 up plenty high to use my 30" 10 ton jack stands.I bought one of theses daytona jack. It's been great. No issues in 3 or so years of use.
Yup.I really like my HF US General toolbox. I was told they are made from an older SnapOn model. It’s heavy duty! Ask @Tikicruiser and @Stumpalama they helped me move it last weekend.
Converting my ARB indicator lamps to LED parking lights. Pics to follow.Not a lot of action in here recently. Every one must be busy working on their junk.
Well, the fun never ends. I followed OTRAMM’s knuckle rebuild video to a T and reassembly of the knuckle was going great until I went to install the new Aisin locking hub. It wouldn’t slide onto the splines so I tried tapping it on with bearing race driver and busted my brand new hub !!!
It’s the right spline count, 30. Anyone know if this is fixable or do I need to buy new axles with good splines?
you can just replace the gear. I think Marlin makes them. They should just slide over the burf. You should not have to hit it on. You probably got the wrong spline count. Where they mini truck hubs?
For the shade tree/ weekend wrencher, they are quite sufficient, for sure.HF has definitely been stepping up their game. Their toolboxes are a better "bang for the buck" than the other options out there. They're certainly not the best, but you seem to end up paying a lot more to get better quality.
I would pull the busted hub insert out and try to install it on the birf. Flip it and use the undamaged side of the hub insert.The birf and hub are definitely both 30 spline. I double and triple checked. The new hubs are for a 79/80 Land Cruiser and mine is a 6/79. The old hubs were crappy AVM bolt-on’s that I’m replacing with Aisin’s on studs.
My truck is from South America and has all kinds of hack jobs that I’m now correcting so I could easily expect the birfs being hammered on and the splines messed up.
First pic is the old hub and second is the label for the new Aisin hub.
Thanks for the input.
