- Joined
- Sep 25, 2011
- Threads
- 89
- Messages
- 3,678
- Location
- Harbour City, the New Southern Wales
- Website
- www.freewayoneentertainment.com
Where were you when I figured a clear coat was the only option??
This picture was my homescreen on my phone for a long time, til I got a 55 of my own!
Love the look.
Okay, perfect timing! So having read through this, I am a little lost on a couple things. Hopefully, my incomprehension can aid some other members. Just treat me like I'm 5...
So my 40 has a nice patina but also has a few rust spots like in the channels on the roof. I would really like to "stop" the rust and make it look prettier again.
From my understanding:
For outside and inside paint
For EVERYTHING underneath
- Use CLR on a scotchbrite to clean where all the paint is and used to be - yes
- Use a rust converter (I have VHT brand though I haven't used it yet) on the bare rust only and avoid paint as much as you can - yes
- If necessary (due to too much overspray of converter), clean up again with CLR - yes
- Coat the outside paint and rust areas with either use boiled linseed oil (BLO), penetrol, or parafin (I have also read about ankor wax?) - yes. Owatrol oil is another option too.
- repeat 3+4 every few months - yes as needed based on need
- Probably do an undercarriage wash with pressure washer or something - yes but you might need to scrap the gunk off first
- Spray rust converter everywhere that looks somewhat rusty, fill in rust holes with automotive expanding foam, metal tape, or weld if necessary
- Cover everything in Fluid Film - yes
- Repeat 1+3 every few months - yes based on need
First of all, is that right? - yep!
Second, I was wondering if people can provide some more info about some of the specifics like:
- Where should you NOT use CLR, rust converter, boiled linseed oil, penetrol, parafin, and fluid film? I remember reading something about staying away from rubber? What about plastics? Fiberglass? Electronics? I read that the fluid film can catch fire or at least burn if sprayed on the exhaust
- What is the best thing to use in the roof channels? Just use fluid film? Or spray everything with rust converter? If your roof / rain gutters are leaking then you might need to recaulk them with a self leveling seam sealer.
- I know that BLO and penetrol can be used as additives for the paints. Although this is about patinas, has anyone followed the steps and then painted over them on the uglier areas? I haven’t but. Think painting over BLO is dependent on the paint you use (enamel vs urethane, etc.) the directions talk about which paints work over top
- When is a good time to use an orbital polisher in this process? - Whenever you have paint that can be polished but likely not places where the paint is cracking, peeling, etc.)
- If the rust converter technically converts the rust, why could you not then clear coat? I don't want to clear coat, but I don't understand the reason why the rust would come back if it had been converted. - it converts rust but unless you coat the raw metal with something it will rust again, hence covering with BLO, etc. the issue with clear coating is that unless you have a complete bond/covering then water can creep under it and create more rust.
- Whoever has used penetrol (@Indygbd), is it honestly just use that product and nothing else? The 40 on the first page looks like it had some extra paint added, though maybe penetrol is as much of a miracle worker as I have read.
- @wngrog is there any reason you couldn't just cover the entire 40, paint and all, in fluid film? If it is so resilient, it seems like a great candidate. - fluid film is more sticky thick consistency and I don’t think would provide good results on paint compared to BLO. Dirt and grim would stick to is like crazy.
Land Cruiser rubber and Fluid Film? Grommets, weather strip, etc?
Can I see a picture of your truck?
All your steps up and under are correct.
I would use Fluid Film in the channels as it will creep around into the cracks.
Read the Fluid Film FAQ. It’s safe in anything. It picks up dirt though. It’s stickier than CLR. I would not use it on the paint much. Just test it out. You can decide. It won’t hurt.
All this stuff kills the rust that it can get to. If there is some bubbling under the paint the clear will end up having the rust re appear.
As for the polisher I never used it on my 40 or 45 but the 55....I used it to polish the rough spray paint
@nc116 I bet after a CLR bath a lot of the rust colored spots will go away and a simple wax / oil treatment is all that’s needed. That hood patina is nice!
Here are a few pictures. Paint is very oxidized. Lots of nice patina on the hood.
Is it simple enough just to use the spray cans? Or should I get the special sprayer set from the company?
It would be difficult for me to really repaint it because I would have to remove the stripes and they give a special look to my 40.
