Pimp, you have the later 4-bolt thermostat housing like FJ60s have, so that is the major difference because apparently the shape of that thermostat housing addresses this interference issue.
looks like its time for a new belt![]()
Did you encounter the same misalignment issue with your install? ....... It's only a one inch difference but the rag joint will not allow it.
Question: How did adding 1/16" washers under the left (to the photo) two bolt holes on the mounting plate shift the PS box to the right (to the photo)?
Original:
The Fix?
Final product?
If it works, Kudos!
