PabloCruise
- Thread starter
- #641
Crazy! Your ARB doesn't fit a 55/40 housing, does it?
Look into full float and semi float, also. You can use one of them for both, but not the other way, clear as mud!
Ron’s issue is not his floating rear or non-floating rear but his ARB will not hold air pressure indicating a bad seal or a part out of spec allowing oil to pass back through the same circuit that’s letting air out.Ron, do you have a fully floating rear?
Is that the same as not dropping any pressure?at least the gauge holds pretty good over night.
Holding pressure for 15 minutes sounds like a BS minimal standard to me and not one I would use for my lockers.
Good luck, FYI I always have a spot in my shop for you and your pig if you need help
I agree, but that's the crap they'll tell when something isn't right and they don't know what's wrong.
