I love my DUI, for several reasons.
My stock ‘78 dissy’s Vac Advance was still “working”, but was also the source of my vacuum leak... robbing 44 of power... especially as altitude increased.
I couldn’t find a new vac advance module... I couldn’t find a new dissy, with a new vac advance module, that I was comfortable driving into ‘nowhere’... I couldn’t find a method for resealing the vac advance module, that I was comfortable driving into “nowhere”.
So, I started researching alternatives... and DUI won out...
1. A DUI replaces the dissy, coil and igniter... and requires NOT using the “fat” BY wire, on my ‘78... it has the “fat” pink Yazuki resister wire spliced into it.
2. DUI runs “fully battery power”, so plugs are gapped at .055” and timing is set to about 12*BTDC.
3. Increase in power is significant... in tests, I’ve found I can cruise at 70mph... even fully loaded and uphill. Of course, some of the power increase is attributable to plugging that vacuum leak. Note: I seldom exceed 60... but, it sure is nice to merge into freeway traffic, rather than merely becoming a target.
4. No power loss at altitude... I’ve driven above 7k’ thus far and will exceed 9-10k’ in May-Jun.
Caveats:
1. DUI had gear problems early on... that’s been resolved... just be sure you buy the ‘Toyota Version”, to get the correct gear.
2. There are three Toyota DUIs... I bought the one (blue cap) with the vacuum advance module.
3. DUI’s cap is large... I removed my heaters a couple of years back. So, no problem. Those with heaters may need to relocate the heater pipe that runs along the block side cover.
4. All the electronics (coil, etc.) are in/on the cap... I carry FULL spares, for an easy swap, in an emergency.
5. Easy access to new parts ... as
@Steamer said.
6. Their use of nylon screws prevent arcing... but, do NOT overtighten them... as me how I know.
I was preparing an order when I found a several month-old ad, on MUD. I PMd the guy and worked out a great deal, for the NIB DUI, a set of LiveWire plug wires and everything needed for installation.
I added a relay, to deliver full battery to the DUI and, the results are excellent!!
