I watched a few of Will's reviews and went with the LiTime 100AH LiFePO4 battery with BMS and bluetooth. You can get below $300 now. Placed it under a drawer wing and tied down. Already had power run from starter battery to rear. Added a Victron DC-DC charger 30A. Charges 300W to the LiFePO4 battery.
Nice thing about LiFePO4 is you can discharge it much lower than other battery chemistries, especially AGM. I can monitor the battery, Victron charger and National Luna fridge using Bluetooth and phone. This solution works great for me. If needed, I can connect my Victron MPPT with solar panels for charging if stationary at camp for a few days.
FWIW - I originally put in a dual battery in engine bay - AGM with Redarc BCDC, SBC around 4-5 years ago. LiFePO4 batteries were still pricey. Just replaced the Odyssey AGM (with the same AGM) which served me well over the years. I still use it for accessories and it's wired to Switch Pro. The setup has been trouble free for me. I typically run the fridge off this if I'm not stationary at camp for a few days. I can also easily switch Anderson connections from LiFePO4 battery to AGM aux. for flexibility.
Back to OP, I would go with a simple LiFePO4 battery setup in the interior cabin. Less expensive, less complexity and longer run times.
I also have this setup,
@FrazzledHunter turned me on to the Victron 12|24 charging trick to the GZ 1500x. The Yeti Vehicle Integration Kit has some poor reviews on the initial release and I had already invested in the Victron DC charger.
The one thing I left out of my previous dual battery system was an inverter. That's where the GZ Yeti comes in handy when I need an inverter. I've run a Nespresso machine and small microwave off it, no problems. It's also handy to leave in tent to charge/run personal devices.
When you plan your power cable runs, consider adding an extra run or two and don't be shy on going with thicker gauge pure copper.
